1 - 8 of 8 Posts
fast, not furious
I just noticed that my drivers side upper rear control arm bushing (spherical joint bushing) is now loose. The result is a sound that I have never heard before when slow starting and stop -- KLUNK! After having the wheel off this weekend it is noticeable that it now slides in and out -- the sound coming from the forked end of the control arm are slamming into the top of the wishbone assembly. The dealer does sell just the bushing assembly $56. but, they recommend replacing the whole control arm with new bushings in place $670. Apparently, this is a common problem and there have been several redesigned versions of the complete assembly. Question: has anyone replaced just this bushing set and been a safe/happy money saving driver? It is definitely the easy way out.
Unless the arm isn't holding the bushings and/or spherical joint in place, I don't see why you wouldn't just replace those parts. They're typically pressed into the control arm.
fast, not furious
Thanks, as I am reading a few more posts about the subject. It could be that the control arm is cracked and that's why bushing is loose. I haven't looked at up close just yet.
Illegal Alien
I just noticed that my drivers side upper rear control arm bushing (spherical joint bushing) is now loose. The result is a sound that I have never heard before when slow starting and stop -- KLUNK! After having the wheel off this weekend it is noticeable that it now slides in and out -- the sound coming from the forked end of the control are slamming into the top of the wishbone assembly. The dealer does sell just the bushing assembly $56. but, they recommend replacing the whole control arm with new bushings in place $670. Apparently, this is a common problem and there have been several redesigned versions of the complete assembly. Question: has anyone replaced just this bushing set and been a safe/happy money saving driver? It is definitely the easy way out.
Unless you suspect damage to the arm itself, just replace the outer bushing. The front arms are a different matter, the steering ball joints are factory pressed without replace joints and thus "can not" be field fit, Lotus only sells the complete arm.
fast, not furious
Unless you suspect damage to teh arm itself, just replace the outer bushing. The front arms are a different matter, the steering ball joints are factory pressed without replace joints and thus "can not" be field fit, Lotus only sells the complete arm.
Ok, thanks Julian. I am going to order it and give it a try. It isn't an expensive proposition so it's worth a try. I will post an update. Thanks
It would very helpful to Evora owners if you can provide a DIY guide in the Evora how-to sub-forum when you tackle this.
fast, not furious
Updated Upper Rear Control Arm Replacement 2011 Evora
After I removed the upper rear control arm it was discovered that a crack formed inside the journal that attaches to the upper hub carrier. Lesson: if the spherical joint has slipped it is very probable that the journal has formed a stress crack. I thought it had just lost its pressure grip and that purchasing a new spherical joint would be the easy way out -- WRONG. I ended purchasing a brand new rear upper control arm complete unit
1st step: jack up and supported rear of car and removed driver side wheel
2nd step: removed wheel well felt cover
3rd step: using a 1/2" driver and metric socket managed to get socket inside small window opening for head bold removal. With flat open-end wrench slip horizontal into spring area come back a little to turn wrench vertical onto nut.
4th step: One ratchet click at a time break bolt grip and click, click, click until bolt is off nut. Same for rear most bolt and nut
5th step: remove hub carrier to upper control arm bolt with heavy torque
Total removal time 1.5 hrs.
6th step: install new upper control arm and coat bolts and nuts with thread lock. Lotus specs torque 63 ft/lbs. and hub bolt 99 ft/lbs. One click at a time! (I found it impossible to torque all thee bolts with my torque wrench that has a large head) Install was very easy overall
Re-Install time was 45 mins Felt wheel well cover 15-20 mins.
Illegal Alien
Thanks for the update
1 - 8 of 8 Posts
