21 - 26 of 26 Posts
Discussion Starter #21
Spyder's web site is still up. At the very least, I want to get a roll bar and side intrusion beams fairly soon - I hate just having lap belts and I'm not comfortable mounting harnesses to the back wall of the interior. Of course, in a serious accident, you're probably a goner no matter what, but everything helps!
That piece is not a side intrusion element. It is simply a way to connect the pedal box (& passenger) back to the chassis.
The arrangement is supposed to protect our lower legs in the event of an offset (or full?) front crash, by keeping wheel & tire from encroaching.
Yes, I've grown attached to my feet....
For that longitudinal member (hidden in rocker panel) to give us intrusion protection, we'd need to be on a go-kart track....
Elise Newbie
Great write-up, thanks for sharing! Always loved the Elan, this makes me want one even more someday. Shame it was sold but I hope to see the Elise at some meets this summer!
Discussion Starter #23
Thanks. With warmer weather will attend some C&Cs.
Discussion Starter #24
Groucho,
Didn't want to intrude on other thread (fiberglass repairs).
The battery tray in Elan trunk began to break.
Before fixing the f/g, I put a few bits of dowels in the tray's rounded edge and glassed over those. It was quite sturdy. Never showed any cracking after that.
Jeff
Right, I get that it's going be totally ineffective unless you're hitting a wall or something, but they do call it that so I did for convenience's sake. "Protects both driver and passenger against side and wheel intrusion"
Groucho,
Mine isn't a cracking problem... basically, every once in a while, my wife would notice something drip on her feet. The botton of the airbox (around the trumpets) had been slowly, over the years, cutting a groove underneath to the point where there were some small holes, and I assume she'd get a little gas once in a while dropping down.
I found out a few years ago that the root cause was that the engine mount on that side was wrong, that side needs a mount that moves the engine up a little higher to keep the airbox off the fiberglass, which I promptly put in. Since the engine's out, I figured that I might as well build up the glass in that area again to prevent future drips. Really, I could probably just put in some filler and be done but I thought I'd try to do it right with some fresh fiberglass.
Oh, and my battery is still behind the passenger seat so no trunk problems with it. :) I do plan on moving it to the trunk some day but that'll be another project.
Discussion Starter #26
So, the Buick GN I raced and beat was a 14 second flat car in 1/4 mile. So, even with the "smaller" engine (156 hp vs 178) I had to be a tiny bit quicker.
21 - 26 of 26 Posts
