1 - 3 of 3 Posts
I have posted several discussions and replies the past nine months without I believe an introduction. Not to be confused with a scammer per Forum rules here it goes...... Not a gearhead but am a sports car fanatic. Have owned a TR 3, Spitfire, a Morris Minor convertible, 356 and Miatas. Always wanted a Lotus since reading Road and Track and watching the Avengers(Emma Peel's Elan S3) in the 60's as a kid. Searched for a stock 2011 Elise SC with low miles for a year. This was to be my final sports car. Found one in February and have logged 1500 miles so far on country roads and trips to the coast and through the Cascades. Will not track it but plan on many trips. I like to drive(drove my 356 back in the 80's up the entire coast from LA to Victoria BC) and plan to visit Crater Lake, Mt Rainier, The Olympics, Central and Southern Oregon Coast, Pendleton by the end of next summer. Live in Portland and joined the local Lotus club. Absolutely love the car and probably won't part with it until I am in the ground. Proud to be a member of this great Forum.
July 2020 Cannon Beach, Oregon
1268756
Nice car (and photo).
These cars are enormous fun. Good for you.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 3 of 3 Posts
