The fuel required to cruise around town is essentially the same as when the car was NA. However, every time you give the throttle any push, the power delivered is much greater than it was NA, so the fuel consumption is much greater as well. You essentially will have the same accelleration times in 5th gear as you did in 3rd. That doesn't come for free you know!
The injectors in the 300 kit are carried over to the 400 and are designed to run in excess of 400whp. The idea is that as you move up the power levels, you don't have to keep buying larger injectors...
-Phil
-Phil
