1 - 3 of 3 Posts
Hi all,
second batch of new "reversed" and for whatever it means " unbreakable " HML cwp sets is almost sold. Now for the month October I can offer special deal for set. PM for more details and price.
cheers,
Harry Martens
www.ds-vitesse.com
All gearbox parts and gearboxes ( fully rebuild) in stock for Lotus Esprit S1, S2 , S3 and Turbo version. So " previous" and C35 models. IMG_8966.jpg
Integrator
If you wait a little, you will be able to get The Ultimate Best CWP from me.
All NEW geometry 4.428 ratio improved design with stronger teeth.
Final Gear Ratio : 4.428
Tire Size : 285-40-18
Max Power RPM : 6200
Limit RPM : 7000
Gear Ratio Compound
1 .... 2.920 .... 12.930
2 .... 1.940 ..... 8.590
3 .... 1.320 ..... 5.845
4 .... 0.970 ..... 4.295
5 .... 0.760 ..... 3.365
Gear MPH/1000 MPH @6200 MPH @7000
1 ....... 6.21 ..... 39 .......... 43
2 ....... 9.35 ..... 58 .......... 65
3 ...... 13.74 .... 85 .......... 96
4 ...... 18.69 .. 116 ......... 131
5 ...... 23.86 .. 148 ......... 167
Gear RPM drop (change @6200) RPM drop (change @7000)
1->2 -2081 (To 4119) -2349 (To 4651)
2->3 -1981 (To 4219) -2237 (To 4763)
3->4 -1644 (To 4556) -1856 (To 5144)
4->5 -1342 (To 4858) -1515 (To 5485)
Discussion Starter · #3 · (Edited)
:Really?????
:All theoretical, non proven. What if some part on shaft does not fit? For example the synchronizer hub for 1st and 2nd gear. Special splines. Do you have bleu print or do you use used parts to fit?
Limit RPM : 7000
Gear Ratio Compound
1 2.920 12.930
2 1.940 8.590
3 1.320 5.845
4 0.970 4.295
5 0.760 3.365
1 6.21 39 43
2 9.35 58 65
3 13.74 85 96
4 18.69 116 131
5 23.86 148 167
Gear Change RPM drop (change @6200) RPM drop (change @7000)
this is all irrelevant information
My 16 sold reversed cwp set are proven unbrakeable!
Now special offer and stock.
All gearbox parts for Lotus Esprit in stock!!!!
Cheers,
Harry Martens
1 - 3 of 3 Posts
