1 - 6 of 6 Posts
I just installed the Aluminum Heat Shield and it touches the valve cover. Is this intended or am I missing some sort of spacer?
Thanks....
Thanks....
I have the carbon version, but it doesn't touch if properly installed. Did you follow the instructions?
San
Discussion Starter #4 (Edited)
It didn't come with instructions. But seemed pretty straight forward to install... basically mount to the bottom of rubber isolators.
I am using with the stock IC, if that makes a difference...
shay2nak
i added a couple washers as spacers because I was getting a rattle on the driver's side bracket. I'd just glue 2 or 3 washers on the brackets (all 4 corners) and install it again.
1 - 6 of 6 Posts
