1 - 11 of 11 Posts
Hey guys don’t have my manual with me to reference so have a question. I was thinking of replacing all rockers when I replace my cam (haven’t inspected it yet but figure if it isn’t wiped it will be) and was wondering. Being as there appears to be a rod that runs the length for the rockers can you take them out with engine in car?
All I’ve found on this is a few pix and a couple peoples site but their engines have all be out of the car when done
The rocker panels are not something you want to mess with if you don't absolutely have to. They are not bolted onto the car, they are glued and have A/C and coolant lines running inside on both sides. Are they damaged? Post photos of what you are thinking of working on.
Good luck!
Not that many ppl have experienced wiped cams, so expecting yours to be in that group may be a bit much.
Engine stays in car.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 - 30 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping. I use Mobil 1 5w-40 Turbo Diesel oil.
Car at 85k, no issues.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
** The Enforcer **
Good luck!
He's asking about camshaft rockers and you're talking about the door sill covers.
San
`08 Elise-SC-220
Good luck!
I think he's referring to the cam followers under the valve cover, where valve lash is adjusted. >:)
There is enough room to remove the rod. It comes out the driver's side, so you'll have to move some items around like the coolant tank and hoses.
Wow, do I feel stupid. :shrug: That is what I get for reading and responding on my phone! Sorry all, that was dumb of me! :facepalm
Rocker & Cam removal - see attached guide. :nerd:
Disclaimer - I have not used this guide, I only have it for when/if I switch to Stage 3 cam.
As posted above, the shaft slides out the driver's side of the engine after moving the coolant tank out of the way.
If you are buying a stock camshaft, they come with new rockers from Toyota. If you are buying from an non-OEM supplier, there are a few that sell the cams and rockers separately for too much money.
Do a google search for the camshaft part number 13501-29025. You should be able to find the cam and rockers for about $250 from online Toyota parts dealers.
I believe the conventional wisdom is to replace the rockers with the cam (assuming you even need a new cam). There are some very thoughtful discussions on this site about OEM vs aftermarket stock configuration. Look on this site also for a tricky (yet very easy) way to remove the chain tensioner. With any luck, you won't have to do the work. Don't confuse discoloration for wiping. Good luck!
1 - 11 of 11 Posts
