1 - 16 of 16 Posts
So before I put this front clam back on , I see a lot of different discussions on the ever famous radiator, 2005 Elise and is the original, can someone plz send me a link to purchase the best bang for the buck , preferably 1 that exactly fits , going to be traveling over 1000 miles and dont want to have any issues, also anything else I should maybe do since clam is off Thanks guys sorry but very new to Lotus
Not sure about the rad but I would do this. Been meaning to do it to my car since mine failed.
I got Wizard Cooling, thicker version. Thinner v. is easier to install. USE`
Perhaps very slightly more cooling capacity with thicker.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
5. Transmission:
And, use:
How to Bleed Brakes
How to Search:
THANKS FOR THE INFO 👍
Administrator
Four of the vendors on here carry just what you need as far as your cooling concerns. Check out blackwatchracing.com BOE Fabrication GregsRaceParts.com GRP https://www.inokinetic.com/
Reactions: LotusRookie05
2005 Lotus Elise
I used this one, it worked fine. The job is a pain for sure. If you’re going to do the resistor replacement too, then you will have to disconnect the ac lines, which will make removing the old radiator a good bit easier (avoid cutting the access holes mentioned in this thread);
I've removed my front clam probably 8 different times. I'm down to 1.5 hours, but it's still one of the least favorite jobs to do on the car as it's so flimsy and on top of that the headlight buckets are super fragile.
With that said, just replace the radiator now! Talk to Shinoo at Inokinetic.
Check out the BWR F1 Radiator...since you got the clam off now is the time! Its a work of art and man it is LIGHT. Aluminum end tanks (like it should have been from the beginning) , a lot more tubes and fins but its thin and did I say before it is lightweight? Fred at bwr is a pleasure to work with.
Thank you sir , I’m on it
Discussion Starter #10
Thank you for the ilinks , def gonna make my life easier
I have a brand new high performance pro alloy from BOE. I bought it some months ago planning to install proactively this Summer. Box is opened as I wanted to check it was intact when delivered. When I went to scope out the job I realized to my chagrin someone else had already replaced the OEM version. Ah well. It gave my children something to make fun about. It's $600 on BOE. Assuming shipping is not more than $50 or so, I'd be happy to sell for $500 shipping included. I guess I should post this on the Parts for Sale section and will do so. Just haven't been able to find 10 free minutes.
I second kudos to Fred. I have his single Penskes and he is always very helpful.
Nice! perhaps also replace the stock radiator hoses with silicone ones - with built in bleeder valves just like factory. I saw it on Inokinetic and the bwr site.
I also have the BOE Pro Alloy that I installed many miles ago with no issues and cooler running temps. That's a fair price above! Be sure to install new hoses, silicone even better...
I’d do rad, horn and resistor pack if I took my clam off. Maybe brake lines?
I’ve actually had the parts for the resistor pack kicking around for years as I lost speed 3 a while back. When I lose one more, I’ll do it.
Make your own resistor pack.
I always thought this way to fix was worth a shot. Basically you need a borescope and a pair of needle nose pliers. You leave the old pack in and just pull the wires out. No hassle of recharging the AC. Worth trying because if it doesn’t work, you just pull the blower like the traditional repair method.
1 - 16 of 16 Posts
