Rust on Ignition Coil #1??
11677 4
Pulled out my ignition coils today and #1 looked a little funny:
Auto part Subcompact car
Then, on one side of it, something else a little odd:
Auto part
Another close-up of the Rust and black sludgy stuff:
Auto part
I pulled the Cylinder Head Cover, and took a peak at the chamber for #1. You can see lots of corrosion down there:
Auto part Engine Machine Automotive engine part Metal
The other 3 Coils and chambers (unsure what the official name is) are spotless
Thoughts on what caused the rust and sludge? Perhaps a bad seal at the spark plug, allowing some air/fuel mixture into the chamber?
I'm taking it to a dealer in the next couple of weeks for some un-related and relatively minor warranty issues, and I'll be adding this one to the list.
1 - 5 of 5 Posts
The cause of the corrosion and sludge shown in the photo from my post was a leaking spark plug tube seal in the valve cover on the #1 tube. Ever since the seal was replaced, the tube cleaned and a new spark plug and coil installed under warranty by Lotus I have not had any further trouble. Sometimes in absence of the black sludge where there is only the oxide formation the cause has been traced to water getting into the engine compartment, onto the valve cover and running into the spark plug tube.
2nd, mine had this as well. I had to soak out a good inch of oil when I needed to change my plugs. Put 4 new seals (just in case) in the valve cover and problem solved.
1 - 5 of 5 Posts
