1 - 19 of 19 Posts
Painted my hubs... Might be a bit bright but add break dust and I hope they will be good...
All I used was etching primer and engin enamel.
Discussion Starter · #2 ·
Here are a few more
Perhaps black would look more natural.....
I did the same using plastikote silver brake caliper spray! Makes a world of difference! Looks great! I was so upset picking up a brandnew elise in 06 with rusty hubs! Hasn't lotus heard of cad plating? I'm sure the weight is negligable.
I did the same thing. Rusted rotors is a turn off :D
I sprayed the entire rotor black though. No need to mask it off. First time you step on your brakes it takes it right off.
Dang it another thing to do. I don't know why I did not think to do this went I painted the calipers.
I don't think I would spray the entire rotor as they are drilled. What gets the paint out of the holes?
I think I'll do the same when I touch up the Calipers. I might just spray the whole thing and let the pads peel the overspray :D. Black is the way I'll go.
Zach - did you put your car on jack stands and do all 4 wheels at once?
Discussion Starter · #14 ·
Yeah I should...I now have 2 wheels done is Silver, the other two done in black. Did that to see what i liked better. After looking at it, I am going to paint over the silver ones.
Post picks soon !
Z
Thanks to the OP for sharing and showing. I did the same in silver. I like the silver for my stock silver wheels. I also painted my rusty lug nuts in black. My calipers were painted by the dealer in black from the previous owner.
Rusty hub
I used purple power rust treater/remover before etching/priming and painting
pic after purple power rust treatment
prep work
after painting hub
happy with the result:D
Since the car was on stands with wheels off, I flushed my brake/clutch fluid since it was nearing time to do them anyway. Also cleaned out the wheel wells and inside the wheels
Been meaning to do this, where did you guys get your paint and rust remover from, just an auto parts store?
I used some cold galv and black high temp paint I had laying around. Both can be picked up anywhere that sells spray paint. It's held up great since I did it. Rusty rotors are yucky :)
1 - 19 of 19 Posts
