1 - 3 of 3 Posts
Hi,
trying to find out some info re the S1 speedo. The speedo on my car (Stack non CAN type) reads high (20% ish). I've performed the "hard reset" but to no avail.
For those of you not au fait with the S1 it uses a speed sensor on the rear LH hub with a toothed ring on the outer driveshaft joint. This is obviously fairly new on my car so I'm wondering if it doesn't have the correct number of teeth (too many??) & hence is giving the speedo an incorrect signal. Question then is does anybody know how many teeth the ring SHOULD have on it?
Any help on this frustrating subject would be much appreciated as I'm relying on the GPS speedo at present which isn't exactly ideal.....!
Thanks,
Stew
1 - 3 of 3 Posts
