I know that on my Ducati, the stock Sachs shock is the first thing to replace to get it to handle better. Do they make a few different "quality" levels, because I thought their products were more "oem" quality than top notch aftermarket?
Yes, these are OEM-like in their build quality and expected longevity. Most race shocks need regular rebuilds. Note how the eyelets have rubber seals - this is great for those people who live in inclement weather - an OEM feature.I know that on my Ducati, the stock Sachs shock is the first thing to replace to get it to handle better. Do they make a few different "quality" levels, because I thought their products were more "oem" quality than top notch aftermarket?
Correct. No tools required.ahhh nice. I'm a bit confused...so compression/rebound are both adjustable, but only AT the same time, hence "single adjustable" ??
Yes...I have the same setup. Love the ride and love the handling. But like on our ride today I hit several spots where it bottomed out terribly.I have them on my car.....great handling...but they DO bottom out once in a while on bad bumps. TVACC I believe you have the same symptoms ? ( may be the setting....any suggestions ? ) ( 8 - 10 )
I just ordered the last available set and THEN discovered this thread....Yes...I have the same setup. Love the ride and love the handling. But like on our ride today I hit several spots where it bottomed out terribly.
I am contacting Sachs about this. It is not acceptable to me. I have tried every setting I can think of. I am worried about damaging the mountings for the shocks. That is how HARD the bump is.
They are progressive rate springs (as are the OEM Track Pack springs), so they start out at a lower rate and then increase rate as they are compressed. I'd guess that you wouldn't have to worry about "bottoming out" with these springs. If the springs are the same diameter as the OEM springs, it may be possible to swap springs... I'm sure Shinoo could answer that question.I just ordered the last available set and THEN discovered this thread....
I'm wondering...Does it bottom out in the front or the rear? The minimum spring rate in the front is much softer than stock and the minimum spring rate in back is much stiffer than stock. I'm mainly getting these for ease of ride height adjustability, so I'm wondering if they can be used with the stock springs?
I am going to have to bring mine back as well. I hope it is not the shocks for except for the bottoming....they are great.AutoEurope is supposed to be checking mine out ( whenever I can get it IN )... Tom said that they adjusted the front end too low. So, it's not a shock problem, it was in the setup.
Here's another photo with the Sachs mounted on the car.
Sector111 quotes the rates of the front springs on the Sachs setup as 177/531 lbs/inch... while the Track Pack springs are 180/271 lbs/inch. Still I don't recall the shorter coils on the Track Pack being so completely compressed.wow, are the springs too soft?![]()
