The bracket that the ball sits in shattered, those pieces now reside inside my car. Hoping I can replace the bracket without losing the whole mirror.Is the mirror still hanging on? Mine got hit by a kicked up tire on the interstate last year. It whacked the mirror so hard it flipped around and was totally jacked up looking. I pulled off the next ramp and spent about 20 minutes fiddling with it. I was able to actually get it back on and looking fine. I never would have thought I could be put back to normal but I was able to, it just took a while lining it back up and twisting it right.
Right?! :facepalmWho put that pole there? :facepalm
Goof off might be mineral spirits, not sure. But Goof off will take all that yellow off, just quickly follow it with soap and water and wax.^what he said.
properly wash/clean the area, then try clay barring the paint transfer. This should get most of it off. I heard of shops using mineral spirits or paint thinner to wipe that stuff off (not sure i'd try this) After you get the Yellow stuff off, you can correct/buff out any scratches/dull spots with a polisher and compound.
