1 - 13 of 13 Posts
Has anybody else noticed that the seatbelt buzzer sometimes will just deactivate itself and make no sound upon starting and driving the car, while other times it’ll buzz for a minute or so before shutting off?
Is there a way to re-code this to just be off all the time?
Administrator
Maybe check your connection under the seat?
My bad I didn’t explain it well .. it is the same beeper / buzzer that happens if you take the belt off when driving or if you’re not buckled up when starting to drive. Sometimes it beeps sometimes it’s silent !
If it beeps while the belt is buckled, and you're stationary, then that's probably a few different things not right. Here's how often, and under which scenarios it should make noise:
Rectangle Font Circle Number Magenta
Administrator
I would try reseating the under seat connection.
Reactions: JTM09
Discussion Starter · #9 ·
thanks guys .I'll see if I can get to the plug. No water issues at all.
It does not beep when buckled.
Today I started the car and drove 3 times. All 3 times the buzzer went off for only 30-ish seconds with the flashing light, then stopped buzzing even tho I was not buckled (dont tell my mom).
I am under warranty so I am not worried, I'd like to totally disable it honestly.
Just find it so strange that it does something different each time :rolleyes:
JTM09 you have a GT? boy I've had mine for 5 weeks and already had several major issues, good thing I was trained for almost 7 years on an Elise or I would have jumped off a bridge lol
The problem now with warranty you could wait for a part for several weeks or months o_O o_O according to my tech, when the parts are ordered, they now go from the supplier to Lotus and then to the dealership, Lotus doesn't stock anymore...
The chime/buzzer is integrated into the instrument cluster. AFAIK, there's no programmable way to disable it. You could easily defeat it physically though:
Rectangle Font Parallel Circle Logo
Just jump the 2 pins in the seat belt switch connector, and it will always think you're buckled in.
Discussion Starter · #13 ·
Yes, 21 GT. Picked up a few weeks ago with 6400 miles so hopefully the bugs were addressed already. How many miles are you at and what went wrong?
great info here 👍
1 - 13 of 13 Posts
