1 - 6 of 6 Posts
We do not have that system on the Elise/Exige, correct?
Correct. The tube for air injection is blocked from the factory.
Thank you, although I was hoping I was wrong. On s2ki.com, a company came out with a little magical black box that allows you to remove the airpump and all the vacuum lines and it tricks the ECU in to thinking that the pump is operational. Saves about 10-12 lbs. Darn
You were hoping your car was 10-12 pounds heavier so you could spend more money to make it weigh what it weighs now?
Lotus has already done that which you want to do.
xtn
xtn
Interesting way or wording it. I was hoping my current weight included a 10lb part that could be removed and replaced with a 1 ounce resistor.
1 - 6 of 6 Posts
