Sector 111 Boomerang Rear Tow Hook
3576 11
I just bought the "Boomerang" rear tow hook from Sector 111.
Do they rattle if I don't put something in between the tow hook and the rear diffuser?
I saw some of the members putting some sort of padding in between... (here's a previous disucssion - link)
Frank Amoroso -
Waydui -
1 - 12 of 12 Posts
I put the soft side of industrial strength velcro on mine in a couple places to cushion it. Attach it to the tow hook and not the diffuser to make sure no heat related issues occur.
Did yours come with washers and screws? I just got my shipment by FedEx, and only thing in the box was the tow hook...
+1
I purchase mine used and only got the tow hook as well. Are longer bolts and washers required?
Yes, you need new hardware (mine did anyway). A longer bolt and several flat washers to bring the indention level with the rest of the diffuser. I went to a higher level hardness bolt as well. The other thread gives details on the bolt and washer combos some have used. Make sure you leave the stock washer (which has a lip on it) in the stock location and layer a washer or two on top of it, then the hook, another flat washer then bolt it down.
Hi Patrick,
I first tried mine without the velcro/padding and I got an occasional, slight banging noise.
The "tongue" is rather long and being held in place by only 2 bolts at the other ends, it did tend to bounce a bit. The velcro fixed it right up. No noise now. :up:
All new hardware for me too, although I re-used the original "lipped" washers.
Haven't had to use the tow hook yet, which is fine with me!! ;)
Regards,
Wayne
So what has everyone figured to be the best installation method?
Bolt (M8x1.25x35mm), lock washer, fender washer, tow hook, washer x 3, OEM fender washer.
or
Bolt (M8x1.25x35mm), washer, fender washer, tow hook, washer x 2, OEM fender washer
or
Bolt (M8x1.25x35mm), fender washer, tow hook, washer x 3, OEM fender washer
or
Bolt (M8x1.25x35mm), fender washer, tow hook, washer x 2, OEM fender washer.
Of course there are many more options and combinations and I have read all the links, but a final answer was never truely given.
Thanks!
I use OEM (with lip), 2 fender (same diameter as oem), tow hook, regular (non-fender) washer, locking washer (split ring type), bolt.
Don't forget to add a bit of Velcro as above to prevent rattle.
1 - 12 of 12 Posts
