http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
Front lines:
There is a small rectangular hole in metal under the access panels and the grilles. It is the size of a pack of cigarettes.
Driver's side is, of course, tight, but is certainly doable.
Because of hard metal lines (a/c, etc), the passenger side is tighter.
I ground down 4 wrenches, which were spares.
I left the ss line loose at caliper end and was able to turn the line with one hand and hold the wrench with the other. That may have been a mistake; not sure.
Then removed caliper and attached ss line.
But, I kept the swivel fitting loose enough to turn the line so it curved to the caliper properly.
Exiges haven't the same access panel, grilles and clam must be removed IIRC.
