1 - 2 of 2 Posts
I just bought a Sector111 battery bracket off of a fellow member. I only have the bracket. Can someone post a picture of what the rest of the hardware looks like. Looks like there should be a large brass washer, one foam spacer, and one rubber spacer.
My plan is to eventually replace my stock battery with a PC680 or the equivalent. I assume there is a way to do this if I don't have the other miscellaneous pieces?
Thanks in advance.
Thanks in advance.
As I recall I only got the bracket and had to buy a washer and a lock nut. But I could be wrong.
I don't have rubber or foam under my battery.
Go to the local bolt shop and get the right size locking nut.
1 - 2 of 2 Posts
