Hi All,
While installing the LETSLA kit, I noticed a problem with my shift cable, at the transmission end. The black plastic sheath is no longer attached to the cable housing. This means that when the shift lever is pulled toward the rear of the car, the plastic sheath moves with the cable end, and some cable becomes exposed. This cable is free to bend, so it doesn't push on the L-bracket properly.
I don't *think* the plastic sheath is broken, as it still has a fat end on it (which I presume should be in the housing).
Has anyone had this happen? I have a temporary fix on there right now, consisting of a zip-tie pulling the sheat toward the housing. Clearly this is not a permanent solution.
Josh
2005 Elise Mag Blue
Josh
2005 Elise Mag Blue
