1 - 17 of 17 Posts
Less is Better
Try the washers and screw method first. It's known as "Stan's Mod". It's basically free and you don't have to drill new holes in your chassis, although you might have to open up a hole in the shifter support.
I have already done this mod but still feel there is some side flex.. Dont know how much of a difference it will make if I also drill the holes?
I did Stan's mod, and it did tighten up the shifting. It's free and very easy to do. There is already a threaded hole in place, like me73 said, may have to open the hole in the shifter a bit to get a straight shot at it.
Do both...takes that lateral flexing of the base out. I swear the shifting is truly craptacular oem...
I did STan's and Sector mods, SSC shift cable, Cross Gate cable, Jim Clayton Big ball, MT-90, GM synchromesh blend, I have dumped the transmission maybe 3times to make sure all dino gear oil is out. It is much lighter in action and and precise, but now I am just dealing with garden variety notchy-ness that makes shifting on the transmissions schedule and not my own. thwarted desires. It was simply heartbreakingly unacceptable out of box. oh well. but yeah both those mods help with the base flexing. The shiftkit came at the time with a long drill bit. just drills all the way through the plate if I recall from inside the cabin. It cinches if up nice.
Anything you can to help. Don’t be concerned about drilling through the floor. Nothing to it.
Okay thanks! Do i need to buy this from inokinetic, or just install two srews on my own?
See #5. Get their product.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
I keep seeing the term "screw" used in Stans Mod on this post and just wanted to make sure you don't use a screw. Use a bolt or machine screw.
Discussion Starter #10
Yes what I mean by screws are bolts / machine screws, just my english that is not that good..
[/QUOTE
How about a cap screw or a hex head cap screw, the word ”screw” can be used for many types of fasteners. Look it up, you will be surprised.
One thing I'd note - I had rocking after applying the 'Stan's Mod' bolt, but the cause was that the front of the shifter frame was convex with respect to the floor, resulting in it allowing a rocking motion. Once I flattened it out with a little artful crescent wrench metal brake work, the rocking went away entirely and the mount is now as rigid as I can imagine wanting.
Discussion Starter #15
Do you have a picture of what u did?
True CRG53 just wanted to be sure he wasn't thinking sheetmetal or wood screw. By in large on this forum users do the right thing but on some of the other forums I'm on bubblegum, duct tape or flexseal is all too often the answer. I had even included machine screw but forgot to include other variants....
If you look at the last picture in this post you will see the flange I'm talking about on the front of a similar gearshift/parking brake assembly (part E120F0001F for my '05 LHD Elise according to my parts manual). The front flange was not flat, so there was a low spot in the middle that contacted the front seat rail extrusion and made a fulcrum for the housing to rock on. Tightening the screws did not help much because the assembly was never really clamped down to the floor extrusion.
It's brake bent welded mild steel sheeting, so is pretty easy to bend. I used a 300mm Crescent wrench on one end and large vice grips on the other and just bent it until it was flat (only 3-5 mm was necessary). Once I did that, the center of the flange no longer touched the floor, and the front of the assembly is now much more firmly attached to the floor. Another change that would firm things up would be to replace the plastic threaded inserts with rivnuts/nutserts or something similar to get a more positive connection to the seat rail and greater clamping force.
1 - 17 of 17 Posts
