1 - 8 of 8 Posts
Administrator
I would contact Inokinetic for advice.
2009 Exige 260 Sport
I did contact Shinoo, he asked to have the part removed and send it to him for repairs; my problem is one of time since my car will be shipped to HI this week; and Harry said the entire unit needs to come out to remove this linkage.
Administrator
Sounds like you have no choice but to wait till you get to HI and then remove and send it. GL!
This happened to mine too (after years of service) and Shinoo fixed me up.
I could remove the part with the bearings, spring and pins without removing the whole shifter mechanism, but then, I do not have a passenger seat, so you might need to take that out.
For a few hundred miles, that pivot pin looks pretty hammered. Mine is way less worn than that. The motion of the stick is limited in the RH direction by the gearbox (not the shifter), so you should ensure that the bearing is not running out of range.
A little grease might help avoid the problem, I put some grease on the shaft last time I had it dissembled to replace the spring.
1 - 8 of 8 Posts
