I believe thier engineering branch does a lot of consulting work for other companies with engines (ie GM ecotec). I'm sure they've run the numbers but for low volume cars its tough to design and create your own engine from scratch
No, the Evora has the same motor as the Camery. The IS350 is the same base engine, but with direct injection. The IS350 engine is also 306hp.One other question. Is the Evora's engine the same as the Lexus IS 350?
I am the same way. I am a Toyota person. Have owned Toyota all my life. I was surely a part of my decision to get the Elise.I consider the Toyota engine in the Elise as a major plus.
I don't think I'd consider buying an Elise otherwise.
Probably I'm in the minority though.
Beat me to it! Agreed. With the sales numbers Lotus puts out yearly it would be absolutely ridiculous to produce or adapt a facility to make engines. They contract out this business simply because it's much cheaper and reliable.Lotus designs engines, they just don't build them. Starting a manufacturing facility is way too costly and risky. At as low a volume that Lotus cars are produced it wouldn't make financial sense.
Like TOYOTA! :nanner2:The only way I see Lotus making their own engines is if some other car manufacturer with big $$$ buy them out.
...the 2GR-FSE used in the IS 350 is a fantastic motor (a ward's ten-best winner for four years running), but the block modifications it makes from the 2GR-FE used in the evora leave it unsuitable for transverse applications...One other question. Is the Evora's engine the same as the Lexus IS 350?
correct - infact lotus does lots of engine design, and combustion cycle research, and managment.I believe thier engineering branch does a lot of consulting work for other companies with engines (ie GM ecotec). I'm sure they've run the numbers but for low volume cars its tough to design and create your own engine from scratch
Thank you. I vaguely remembered the issue (it's been a while for me). But that issue and some rumored engine sourcing for the new Espirit (which is also a bit vague for me) was what prompted to start this thread....the 2GR-FSE used in the IS 350 is a fantastic motor (a ward's ten-best winner for four years running), but the block modifications it makes from the 2GR-FE used in the evora leave it unsuitable for transverse applications...
...it's a longitudinal-mount-only engine, unfortunately...
...all modern toyota multivalve engines are direct descendants of lotus' four cylinder motor used in early esprits, which was sold to toyota so they'd have a modern four-cylinder design...for this reason alone i'm rather fond of lotus' current relationship with toyota, and as mentioned above, toyota's design, manufacturing, reliability, and formula one program are even further plusses beyond that...Keep in mind that Lotus has made their own engines in the past. The four cylinder engine used in the Esprit was designed and built by Lotus.
Lotus has designed some very good engines. The Ecotec was mentioned above but don't forget the famous Corvette ZR-1 engine - yep a Lotus design.
