Didn’t know about this until recently. I have some electric cords outside (in a brutal winter) and this tape does a v good job of sealing them.
Apparently also used for hose (car & home) leaks. Bonds to itself; leaves no residue on the hose or wire.
Anyone else use this? And, for what?
Thx
=gb=
Description from Amazon:
F4 Tape is a self-fusing silicone tape designed for military and aviation use. F4 Tape is the new fast-fusing formula that works in minutes or even seconds, compared to the older 24 hour cure time from older technology. Use it as shrink wrap instead of shrink tubing or shrink tape. F4 Tape was named after the F4 Phantom jet - while intended for high-voltage electrical wire wrapping, this F-4 Tape is very versatile and is ideal as an emergency repair tape! This is the highest quality silicone tape available, and NOT the same as Mocap or Tommy Tape. Lab tested at 950 PSI Tensile strength, this product significantly exceeds military specifications and industry standards for aviation tape. Each roll is 1" Wide X .020" Thick (20 mil) X 36 feet in length. Color is Black.
Harbor Products F4TapeBlack F4 Tape Self-fusing Silicone Tape, 20 mil Thick, 36' Length x 1" Width, Black: Amazon.com: Industrial & Scientific
Thx
=gb=
