1 - 9 of 9 Posts
I had my passenger seat out last weekend so I thought I would show how I mounted my fire extinguisher. Very simple, I pull the alloy straps out from under the seat on race day and bolt the extinguisher mount with 2 bolts (60 sec) After raceway I simply remove the mount and fold the alloy straps back under the seat. As the two seat mounting bolts have Nyloc bolts there is enough tension to stop any slippage. Mine has been on the car for about 3 years. You don't even need to remove the seat and that difficult front Allen bolt to do this mod.
Do you have a picture or link to the type of extinguisher and mount on the extinguisher you use?
I'm planning to install an extinguisher in the car, but permanently, nor just for race days. It's becoming more and more apparent to me how much it is worth it, just in case.
Here are some more shots.
This is what I have for my daily driving 1/2 Kg dry powder
Looks fabricated. Simple enough. Good idea.
Where did u get this bracket? I can't find it on amazon or even on google.
Money can't buy this bracket! :shrug:
It is just two pieces of aluminum bar 25mm by 3mm thick, a couple off dollars worth.
1 - 9 of 9 Posts
