1 - 4 of 4 Posts
2008 Exige S240
Does anyone get a hint of fuel smell after a drive?
I have the carbon canister and a ppe cat in place.
The fuel tank is stock with a 255 walboro pump for
a vf2 SC'er.
What is the chance of a cracked carbon canister?
Do they get "full".
-Robert
I have the PPE Sport CAT and yes I get a fuel smell as well. I replaced the carbon canister thinking that might have been the cause but no such luck. The PPE CAT just smells I have come to realize this.
There are A LOT of threads about fuel smell and how to mitigate them, but I have just come to love getting high while driving.....
I had a slow fuel leak that I could smell from the cabin that got worse and worse. Finally I realized that the fuel line had worn form rubbing on the airbox, and created a small hole which eventually caused the entire fuel system to gush out all the gas as the fuel pump primed.
Check your lines to make sure there are no contacts
I've had carbon canister problems trigger a CEL... maybe check for a leak in the fuel lines before messing with the carbon canister.
Carbon canisters can burst internally and the particles get sucked into the vacuum line and clog the purge valve... easily fixed. Shouldnt smell gas though.
1 - 4 of 4 Posts
