1 - 20 of 80 Posts
2006 Exige
Have been bothered by the excessive play inn the cross
gate linkage on my shifter.So I came up with a solution
that takes all the play out on the gearbox side.I also
reduced the throw by 10% and reduced the friction where
the arm engages (slides)the transmission shaft. Reducing
friction is done with nylatron GS,it's infused with molybdenum
disulfide making it self lubricating with a very low coefficient
of friction.It bolts to the stock shifter base so no need to remove
the clam.It was a really big improvement so I thought I would
share this.Anyone who is interested I will send you the drawings.
If you are willing to make another one (complete as shown) I’ll buy it from you. Let me know.
2006 Exige
Wow! That looks great! I would also be interested in one of these if you decided to make more.
I did make spares but I don’t think I’m
Allowed to sell on this site.I enjoy this
Forum a lot and don’t want to get thrown
Out.I posted this hoping someone out
there had a machine shop and would
Make a bunch. I would be willing to send
them the files.It’s easy to make when you
Have the G code. I also made a improved
Version of the Stans mod that makes the
Stock shifter very rigid.There is nothing wrong with the stock shifter once it’s
Firmly bolted to the floor.Will post it soon.
I'm curious as to what you attribute the improvement - reduction of play in the slot of the inertia weight or the 10% throw reduction? I found a huge improvement on my '07 by disassembling the stock linkage, cleaning all the bearing points, polishing the rust from the slot in the weight, and greasing everything before reassembling. MUCH smoother and easier shifting.
Beautiful part by the way!!!
Selling parts like this tends to be tolerated since it isn't like you're trying to run a business.
2008 Lotus Elise SC and 2007 Porsche GT3
Wow, very nice part indeed. Do you have a picture of it installed? I would definitely buy one of these.
2006 Exige
Discussion Starter · #9 ·
Yes cleaning and greasing will improve things but it's a dirty environment so not a permanent fix.
I achieved the throw reduction by decreasing the length of the lever arm on the cable side.I made
pivot bushings with less clearance than the stock bushings.Then I made the pin that engages the
transmission larger so it has .002" clearance max.Then I used a heim joint in double shear and on centerline
on the pivot point so it would be stronger and not produce any side loads.Since nylatron gs is self
lubricating it's assembled dry and will stay clean.I cut off that stupid bob weight(saves 1#) it's stupid
and can cut your hoses if they sag.Here is a pic.
2006 Exige
Discussion Starter · #10 ·
If San says there is an acceptable way to sell these I will do so_Otherwise you will have to catch
me a track day.I run Thomson and Palmer.Does anybody know when the season will start?
We need this part! I would place this piece in the essential category ;-)
I want one too but would like to know how this compares to the LETSLA and what the LETSLA does that this does not or vice versa.
2006 Exige
Discussion Starter · #15 ·
I don't want to comment on someone else's product.I described what I did and why so I'm not sure what else to
say.When you're going through the gears you're moving the transmission shaft in and out and rotating it.There
should not be metal to metal contact.That is why I used Nylotron GS.This is the only way to do this.I listed
the exact material so other people could copy it.
2006 Exige
Discussion Starter · #16 ·
I’d be interested as well in knowing the differences and the improved Stans mod you had mentioned
So I copied Stan's mod and it was better but my shifter still moved side to side.
This bugs me so I made one that takes all the flex out.It's easy to make so I will
give the drawing/cad file/cnc program to anyone who wants one.Here is a pic
2006 Exige
Discussion Starter · #17 ·
Here is a top view.The bolt on the left(Stan's mod)goes into an existing threaded insert
in the floor.The other bolt ties the right side of shifter to the aluminum block my son
made.I design these parts and pick the materials then my son does the rest.On the
shift lever he ran corner rounding end mills on every surface.so it has no sharp edges.
We manufacture military hardware so we get a little carried away sometimes.
** The Enforcer **
Sorry, but I'm just now seeing this. In the future, mention me (@oldmansan) or PM me.
There are a couple of ways to do this and I'd like to discuss them with you if you'd like. I'll message you my number.
San
Nice work mate!!!!
i just replaced the plastic bushes and glide piece, even this improved the shifter feeling by 100%
posted it on seloc: SELOC Forums
i figured out there's some play in the red marked bush.
Part nr 29 is the plastic bush inside there.
I'm just not sure how to replace it, do you think it's replacable at all, looks quite complicated to get it out...
Source: https://www.lotus-forum.de/WBB/inde...-auf-offenen-schaltkulisse-umrüsten/&pageNo=2
Source: https://www.deroure.com/images/diagrams/11/47_05.gif
1 - 20 of 80 Posts
