Think Telsa.
Electric motors have a constant torque regardless of RPM. This would look more like a ramp, HorsePower wise. Kinda like a rotory engine, (greater rpm's = greater torque).
Bender Rodríguez;1351460 said:
It would probably be uncontrollable without at least adjusting the gearing. If you want a flat horsepower curve your going to have to make allot of torque right from idle and have it drop off fast. Power = Torque x Angular velocity, since it's a liner relationship. You'll have allot of torque at low rpm's, and even less at high, with stock gearing it's going to go from uncontrollable to boring as you sweep thru the band. Well that’s my guess anyway.
yea, pretty much like that.
(torque x rpm) / 5500 = Horse Power:nanner:
So...............
guess what it would be like would depend alot upon gear selection.
Check out the torotrak If you want to see a great CVT. I think it's one of the greatest things I've seen. The addition of the planetary allowing for a 0 ratio engagement is simply gorgeous. varying ratios by oscillation<---brilliant
IMHO 8k rpm's is more exciting than 4k rpm's.
Psychologically, hmmmm, well you know the dumbasses who put the coffee can on the honda and race around making all that racket yet get their butts handed to them by an old run down pickup, because the can and the hood scoop are their only mods they could afford.
Well it sounds faster. It must be fast. So I drive fast! I can hear more power so I perceive more power, I believe there is more power. So much that I can feel it, and you'll never convince me otherwise. The $400 bucks I wasted on this piece of crap is the best money I've ever spent.
Well, We are not so different when at 6200rpm's that lift comes on and oh yea, It sounds and FEELS soo much faster that even though you were pulling as hard from 4k to 5k you appreciate the 6500 to 7500 soooo much more.
As much as I like to believe that I'm a higher life form than ricer boy, in the end we are the same type of organism, I'm just a bit better informed than He and a little less informed than others.
I'll end my day with some thinking, "what an idiot" and others thinking,"That man is a genius."
Unfortunately, I'll wake up with one of the prior.
But if favor shines my way I'll go to bed with one of the latter.
For those moments in between, do what you want, but I'll spend mine as close to the rev-limiter as possible.
anyways, crap here's your thread back.
