Smattering of Oil on 2008 SC Engine
572 14
I am getting a little bit of oil pooling up on the flange where the oil pan mates to the crankcase. The picture below shows how much accumulated after about a couple hundred miles, since I wiped it off. The flange on the front side of the engine had a little smear, but was cleaner. This is a very slight leak -- no oil dripped down on the engine under pan.
I have searched old posts, and there seems to be many places where the oil could come from, if not the oil pan seal. Is this anything to be concerned about -- maybe all 2ZZ-GE's have this issue? Any ideas on what the source might be?
Hood Automotive lighting Motor vehicle Automotive tire Automotive design
1 - 15 of 15 Posts
Administrator
Does it feel like oil or could it be grease from a leaking boot?
Administrator
Maybe check dipstick tube for leakage? Did Kevin have any thoughts of the source when he did the PPI?
2008 Lotus Elise SC
So it sounds like you are saying that this much oil should not be considered "normal"?
I talked to Kevin about having him upgrade the oil pan, hoping the seal on a new one would be better. But we were not 100% sure that was the issue and it did not happen due to the intricacies of the transaction. The previous owner has replaced the o-ring on the dipstick tube in the past. If I feel around the engine from above, I don't find any wetness by the dipstick tube. The source seems to be more on the rear side of the engine, but again I am no expert.
Administrator
This is where a borescope is invaluable. My first one was only$30 but it had short focal length. I just got a newer gen and it has 16" focal length plus two heads to you can see straight ahead and at 90 deg at same time. Much higher quality as well.
2008 Lotus Elise SC
Discussion Starter · #8 ·
Great tip. I have one on order. Thanks.
There are 4 spots in the gasket for the timing chain cover that require RTV.
Art Font Rectangle Circle Symmetry
Over time this packing can start to shrink/crack.
5$ says it’s the lil bit of RTV above that flange that isn’t doing so hot…
To fix it right, the cover needs to come off :rolleyes:
Administrator
1 - 15 of 15 Posts
