Cool, thanks for the info. I drove the Elise to work today,. spent 20 minutes in some stop-go traffic ..and it'll take 10 minutes to drive home. - and then maybe next week it'll take me about 20 minutes to drive to the smog shop., just to get it taken care of.20 minute or so is usually enough. You can check that "readiness is set" via most OBDII apps (torque, for example), and that's all you need.
That said, pay the registration, you can always smog later..
Not my experience, you need a current smog cert to renew registration, that's kind of the point.20 minute or so is usually enough. You can check that "readiness is set" via most OBDII apps (torque, for example), and that's all you need.
Let me clarify my points, and address some things here:Not my experience, you need a current smog cert to renew registration, that's kind of the point.
It has very little to do with the battery and a lot to do with the cats. A long drive will heat them up and burn off the crud.
This. ^That said, pay the registration, you can always smog later..
Yes, a smog certificate is indeed require to renew registration, but as mentioned, one can pay the registration in advance to prevent a late fee, and then smog later on. I actually did this with one of my other cars just a few months ago, as the line at the smog station was too long, saw I could pay the registration fee on time and then smog the following week without issues.Not my experience, you need a current smog cert to renew registration, that's kind of the point.
OK, I get the battery thing now. When I've replaced batteries I use jumpers to keep the car powered, as so much can get lost.Yes, a smog certificate is indeed require to renew registration, but as mentioned, one can pay the registration in advance to prevent a late fee, and then smog later on. I actually did this with one of my other cars just a few months ago, as the line at the smog station was too long, saw I could pay the registration fee on time and then smog the following week without issues.
and in my experience, which is why I was asking, it has a LOT to do with the battery. I wasn't aware when I took one of my folks cars to get smogged one day, the guy at the test center then said it failed, and inquired "did you just replace the battery?". and he told me to then drive it around 100 miles and come back. (and then he was able to pass it)
a quick google has the answer as well:
"Whenever your car's battery is replaced, disconnected, or subjected to a jump start, there's a chance that the vehicle's internal test monitors will be erased. The smog testing facility needs this monitored information in order for your car to complete and pass a smog test."
also in my recent experiences - the last time they smogged my Elise (and Mazda), they didn't even bother putting them on a dyne or testing what was coming out of the tailpipe, they just connected to my car computer and that was it.
If the battery is replaced w/o something to maintain power to the the ECU, then you will likely have sensors that are not in an incomplete state. This will cause you to immediately fail your SMOG test.It has very little to do with the battery and a lot to do with the cats. A long drive will heat them up and burn off the crud.
Indeed. I've always tried to keep the power going to my car via the battery tender or charger when changing batteries. Mostly to keep the clock/radio settings intact. But with my Elise I'm not too concerned about those settings.One of the reasons it's better to maintain power while switching batteries.
YUP!I have an Ecutek Tune on my Infiniti ..I went to smog for tags and as soon as it was plugged in it failed .shows on result ECU upgraded
SMH!
new law or recent law passed in 2022 that tuned Ecus in California show up on smog scan
No state referee.. thank goodnessYUP!
Question - are they letting you re-smog at the smog station? Or are you now flagged to go to the a state referee?
