1 - 4 of 4 Posts
Im about to change my rear toe links out. Can probably get away with locking the hub but I thought it would be a good opportunity to get a full alignment.
Any suggestions for shops in Huntington Beach area?
What are the alignment specs? Has the OEM recommended changed?
you MUST get an alignment. You can get it close but it no where near ideal. the adjustments are too large with the turn of the rod. Rear toe is crucial on these cars. I'm sure you know this anyhow...
Anyplace with a good alignment rack (Hunter, Laser based) will be able to do it. All of the alignment settings are in the computer, they even give the technician instructions on what and where to adjust... just have them set it to stock. I believe there is a Firestone store on Beach and Von's Pavillions. They do lifetime alignment.
If you are concerned, then take it to A1 Smog or Noble.
West End in Gardena are a go to shop.
Cheers.
AKA “Prolene”.
Cheers.
S2000 guys and I have gone to that shop for years. Make sure you don't cancel the appointment and have cash/check on hand.
1 - 4 of 4 Posts
