1 - 5 of 5 Posts
Sorry if repeat but couldn't find anything on it. Rt side hardware of my soft top is comming apart (towards the back of the car). It appears to be held together by a large clip that looks broken. Anyone else have this and can give me some tips
on repair? Thanks
I had one with similar issue (but not as bad) and I just used some black silicon on the edges.
If everything works and you are able to install it on the car then it is just the cover, part #3 below, then you can use some black silicon and glue it back. Make sure to tape the edges so you get a clean finish.
Thank you. For clarification you put the silicone around the edge of part #3, not around the "post" that appears broken in my pic?
1 - 5 of 5 Posts
