1 - 20 of 45 Posts
HI All,
This is pretty important so I thought I'd post ahead of picking up your cars. Below out of the manual for fitting the softop. Of special importance - make sure the steel cables are in the trough as detailed, ie outside the rubber. and you put the left (driver's side on first, then passenger side) to take off remove rightside then left side, it states this is the best way to ensure not damaging the seal.
I really like the warning about not fitting the roof while car is in motion:D
FItting it's a breeze.
Chris
Randy: Stop yelling, "WE'RE GONNA DIE!
WE'RE GONNA DIE!" and say to yourself,
"I can do this. It's only a simple top...I know I can...I really do!" Oh! What's the sense in lieing. You're never going to be able to do it so just accept that as a fact of life. P.S. - I hope you ordered the hardtop.
Discussion Starter · #7 ·
aty,
Yes, full instructions on fitting hardtop.
ground,
Literally one can do it alone in less than two minutes from getting of trunk to finish. Very easy, not like the s1 roof.
Bill S.,
Thanks to litigation prone americans I guess!;)
Chris
Discussion Starter · #9 ·
No, don't really need a hardtop in my climate. Especially since it had it's baptism of heavy rain over the weekend without a leak. The insulation on the softop cuts down on the wind noise.
Chris
I'm glad I was able to find this thread. I wish they would have changed the manual to say passenger or driver side.
When I am in front of the car the right is the drivers side, but when I am behind it, the right is the passenger side:confused:
So we put on the driver side first and then the passenger, and take it off in the reverse order?
I can put it on in about 30 seconds. And don't forget it comes off, FROM INSIDE, at a stop light in about 10 seconds. Especially useful when it's surprisingly warm and you're traveling alone.
Another helpful hint from the manual
Do not store a wet roof in the bag for more than two days.
I guess bacteria and mold can form and the heat from being in the trunk near the engine doesnt help either.
I have the touring package and it isnt possible to stick the roof behind the seats in the bag, it is just a little too tight, but it looks like I might able to do it if I try to force it, which I dont want to try .
Does anyone with a non-touring type top know if it can be done since they are a little bit thinner?
It's a lot easier to get in the car by flipping the roof back first, and then snapping it back in place after you're in. But according to the manual, you shouldn't do that, cause the PASSENGER side has to come off first, not the driver's side.
Has anyone figured out why it matters which side comes off first? There seems to be no difference at all. I was just having this discussion with Yelotus at a meet tonight, and he was of the opinion that it really doesn't matter.
I keep doing it wrong and I don't think it matters...but I put value in the fact they bothered to mention it... it must matter somehow.
Modern Wedgie said:
I wonder if that's just how they've come accustomed to doing it, being right-hand drive in Britain and all. Hmmmm.
That's actually a good thought. How do we find out?
Discussion Starter · #20 ·
Ground,
I can see absolutely no difference on either side, but I figure if they say it's a good idea to do it. Don't know if it really makes a diff, I can't tell
Chris
1 - 20 of 45 Posts
