1 - 9 of 9 Posts
Vendor
I don't now if I have an extra small slave cylinder or something is wrong, but my clutch line pressure with this clutch is 1100psi!!!!! These guys are heavy
I installed one of these and it just made the clutch pedal a little heavier. @Kfennel you must have a pretty small master. Is it OEM?
@Varun916 too bad you did not have this for sale a couple of months ago. What disk configuration did you go with? I did one metal and one fiber. The next time I R&R the clutch, I'll try 2 fiber instead. This clutch does not like to slip and if your revs are not close, it'll let you know whether you are on the street or track.
Later,
Eldon
Hmm, unsure on the config, will ask @titaniumdave , who I inherited it from. You're right that it does not like to slip. The weight was definitely heavier than stock, but I felt that the clutch weight built as it engaged.
The one that I got from ClutchMasters was 2 lbs lighter that the Fidanza flywheel and ACT clutch cover. The big difference was that the inertial mass was much lower.
Later,
Eldon
1 - 9 of 9 Posts
