1 - 20 of 34 Posts
We have added some cool stuff to the blue lightning-bolt since the original post.
Now it has a complete water to air intercooler and fuel surge tank installed and of course a complete new tune.
Here it is guys I am selling our Forcedfed 380 to make room for the next Lotus project car.
Price $55000.00 call John at 925 580 9978
This car has the best of everything and is crazy fast.
View the list of mods
We are offering our 2005 Lotus Elise 380R #1 of 3 built for sale. This car is a complete turn key track car. fresh engine and trans,,spares are available too.
340 wheel hp
280 foot pounds on the race map
Call John or pm for price.
BODY
Forcedfed Front Splitter
Forcedfed Diffuser
Side Scoops
Carbon Rear Diffuser
Carbon Mirrors
Forcedfed front tow hook
Forcedfed rear tow hook
Forcedfed rear carbon fiber wing
WHEELS
PIAA FR-7 Wheels
17X7.5 Fronts
17X8.0 Rear
SUSPENSION
Ohlins double adjustable coilovers
BWR Front adjustable sway bar
Factory Rear Track bar
BRAKES
Alcon 12.9 rotor 4 Piston front brakes
Alcon Stainless steel brake lines front and rear
SAFETY
Welded roll cage
Fire system
Electrical cut switch
Lotus Sports Recaro seat
Schroth Harnesses
Engine
• Forged pistons 82MM
• Ring set
• Crower Billet Rods
• Eibach valve springs set
• Golden eagle sleeves
• Moroso oil pan
• Rod Bearing set
• Main Bearing set
• Thrust washer set
• Complete 2ZZ gasket set
• ARP head studs
• 3/8” pipe plug
• 1/8” pipe plug
• Hondata 2ZZ heat shield gasket
• Polished Crank
• DMC External High Capacity Oil Pump System'
Forcedfed 380R turbo package
Garrett GT2871 Ball Bearing Turbo
Stainless Steel Turbo Support System
321 Stainless Steel Manifold
Spear co Intercooler Assembly
750CM Puller fan
Aluminum Intercooler ducting
Powder-coated intercooler pipe
Stainless Steel 3" Full Turbo Exhaust w/ removable cat
550cc rc injectors with clips
Dedicated air intake system w/ K&N Filter
NGK Spark plugs
TurboXS BOV w/ plumbing for recirculation
All hoses and hardware to complete the installation.
Side Mount oil cooler
Odyssey TC 680 Battery
ENGINE MANAGEMENT SYSTEM
EFI Technology ECU with cluster
3 map tune
TRANSMISSION
Quite limited slip Differential
Exedy Stage 3 Clutch
B&M Shifter kit
Video
http://www.lotustalk.com/forums/f96/lotus-challenge-4-13-14-buttonwillow-photo-video-thread-55255/
The images are current
<img src="http://i242.photobucket.com/albums/ff149/carmod/003-3.jpg">
<img src="http://i242.photobucket.com/albums/ff149/carmod/004-3.jpg">
<img src="http://i242.photobucket.com/albums/ff149/carmod/005-3.jpg">
<img src="http://i242.photobucket.com/albums/ff149/carmod/002-3.jpg">
<img src="http://i242.photobucket.com/albums/ff149/carmod/007-3.jpg">
00 MRS - 2ZZ NA
THAT is a sexy Elise! Good luck with the sale! I love the low 11 quarter mile video on youtube!
Wow price is a lot better than I thought> too bad this wasn't available when I got mine :(
damn seeing the price for this makes we wish that I put a stock motor back in the car and sold it. then bought this for less of a difference than I'm spending on the new motor and build....ugh. Killer car guys, good luck with the sale, thanks for the help at buttonwillow, I'm sad that I guess this means you wont be running the time attack series with it.
..engine photos?
Vendor
I ridden in this car. It is a monster, very well done, and one of a kind. 2 thumbs up!
It would pass only if we changed a few things on the car,, but why waste such a great set-up.
Despite losing some of the great setup, if it were street legal, i'd be interested...just not gonna spend $55k on a track car. There are plenty of options for a track car; I like FC's and that'd run $20k or so, and be part of a well-participated class.
but if I could drive her every day, I'd look into this.
That elise is amazing. :crazyeyes I'm looking into what it would take to register this in Ore. anyone familiar with their process? just moved here from CA, where things were really challenging in regards to registering modified vehicles. thx.
If your moving to portland well they might be able to get your car to pass. You will have to retune the ecu with a "street" fuel map. Which can be done and easily also. The main issue is does the car still retain the OBDII hookup for the fine people at the emissions department to check for engine codes and other dignostics. Im sure the hydro carbons etc... can be tuned so it's a non issue. But in OR there are many counties that require no emissions another thing to think about :coolnana:
Vendor
The fab work is tip-top on this car. If I didn't already have a monster Lotus, I would get this car. Honestly, if you want a track car why wouldn't you buy this? This is $120K worth of car for less than 1/2 price!
bc i'd have to part with the lotus i drive every day, not gonna have two of them. so i'd want this one to be street legal, that's all!
again, for a pure track car, i could get a formula car (butt simple to work on) like a F500 or FC for far less.
Also, you can't really finance a track car because nobody will insure it. If it's somehow street legal, you can get it insured and then finance it...
I'm not sure if you interested parties want to finance or not, but it's just another thing.
The good news is that John has stated it can be simply converted to street legalization.
Discussion Starter #20
Forcedfed 380 For Sale
This is a new blowout price on a fantastic turn-key track car. The first $39,998.00 or best reasonable offer takes it
1 - 20 of 34 Posts
