Set of 4 OEM Brake Rotors taken from 2005 Lotus Elise. $50 shipped but local pickup would be preferred and can discount further if local.
All rotors completely identical, but wear pattern from shorter rear pads left a bit of a lower lip and might be best if used on the rear again and indicated on below life (or resurface it out if you can do it for cheap).
Thickness as follows:
25.3mm (65% life left/REAR) / 25.1mm (55% life left/REAR) / 24.7mm (35% life left) / 24.8mm (40% life left)
Note, only 3 rotor securing screws included as had to use an extraction bit on 4th that was stubborn or overtightened at some point and stripped
(won't matter if you still have your own OEM rotors/screws)
Also have a set of rear pads, Ferodo Racing DS2500 (Street/Track), with a good amount of life left, that can sell for $50 shipped as well. ($189+ new)
Pad thickness as follows:
7.2mm, 6.0mm, 8.5mm, 5.5mm Pads sold
