The ground clearance is 120mm (LSS) or 130mm (base). If the speed bump is more than that you will high-center on it. What that measurement doesn't tell us is whether the front or back will scrape on an incline, such as a driveway. That depends on the angle of attack. Unfortunately, even if you figure out the maximum angle of attack that the car will handle, most inclines don't have their angle posted.Ground Loop said:
Edit: The clearance numbers above were quoted, but I realized after posting that one of them has to be wrong. The LSS is 5mm lower than the base model.
