I received the black gauge face and plexiglass the other day and they look great. But while attempting to install them today I'm fairly certain that I broke my gauge cluster
. While pulling out the speedometer needle the small steel pin came out with it. I tried to put it back into the actuator, but it now has a lot of drag when it is rotated and it no longer has a stop. What I mean by this is that before removing the needles I gently rotated them, they moved very easily and swept about 300 degrees, stopping at zero and approximately straight down. Now the speedometer needle spins 360 degrees but with significantly more drag. The pin is all the way into the actuator but does not appear to rotate correctly.
Has anyone run into this problem before or know how to fix it without buying a new gauge cluster?
