1 - 12 of 12 Posts
I already have the Reinforcer, planning to get the various items for Stan's mod, and will do them together.
Is it better to have the car raised up? I can put it on 4 ramps.
Thanks,
I am not sure it is necessary to do both but have not researched it too deeply. I just installed the re enforcer kit the other day. I would recommend you do lift the car unless you have long arms and lots of patience. You thread the bolt from the bottom and need to be able to hold a hex wrench on the bolt head while tightening the nut inside the cabin. Doing this solo is not very easy and I recommend a second person to help if you can. I had to rig a vice grip to hex key extender to do this myself and probably spend an extra hour since I did not have a second set of hands to help. Good luck!
Oh and you will also need a longer drill bit. I had one just long enough to clear the shifter mount while also drilling straight through the holes. The shifter gets in the way of the drill and it will not work with a small bit.
Thanks for the tips. I do have a wife and 2 sons who can help, Lol. I read through several real old threads, some said doing both will be beneficial. What difference have you noticed in your car?
Ah that will help tremendously! The re-enforcer seems to stiffen up the shifts and make it feel solid with no flex or sloppiness. It's hard to explain, but you will feel it once installed.
Supporting Vendor
Yes, it really helps. The entire shifter mechanism (from shift ball to trans) has plenty of slop that contributes to the poor feel on SOME cars. Addressing each of the areas will result in the best overall feel but our RE-Enforcer certainly helps. Luckily you can also address each over time.
I did both on my car in 2016 and both helped. It's not like either is too expensive to not....
and see #5:
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Is it necessary to disconnect the battery? If yes, only the negative terminal, or both? And does disconnecting the battery mean that some reprogramming of the alarm will be required?
Thanks!
No.\
But, forgot to mention that I'd also realigned (straightened) a swivel joint that looked awry,
Discussion Starter #11
I finished up both mods today. The shifter frame is rock solid. I was able to complete the Reinforcer mod by myself, not hard at all. I used one hand to hold the handle of the long wrench in the cabin, while turning the shorter wrench with the other hand under the car.
1266757
Discussion Starter #12
Hi,
Just wanted to update how everything feels after a day. It feels much more solid and stable.
Overall, I'd highly recommend these 2 mods.
Difficulty level, maybe a 3.
I do have some questions: the shifter stalk can be moved side to side a distance of about 3" (distance at the shift knob).
It's always been that way. Is that normal, and is there any way to reduce this movement?
Thanks,
1 - 12 of 12 Posts
