1 - 3 of 3 Posts
My starter wont crank when I push the start button.
Here the steps:
1- Turn the igniton to second position
2- press the bigger button on the remote
3- push the clutch pedal
4- push the start button
Result: the starter engage (gear throw out), but won't turn
If I maintain the start button, the starter engage and disengage; engage and disengage; engage and...
- The battery is fully charged
- Connections seem good and are tightened
- I checked the grounds
- fuses are ok
- Immobilizer jumped, so can't be it
When I bypass the little wire that plug behind the starter (jump directly to battery +), the starter work (engage and gear turn), so I assume that the starter is ok.
I tryed another wiring hardness that plug to the driver side of the ECU and same problem, I assume that the problem is not in this hardness
So, what do you thin is the problem?
- the relays (4 relays in a plastic box under the ECU)
- the ECU
- the hardness that plug into the driver side of the ecu
- the start button
- other?
What could I check to solve my problem^
So, what do you think is the problem?
I had similar but gradually got intermittent starting.
Jumper cable:
+ to + at starter.
- to - start housing etc
This checks the positive cable as well as the ground path.
But that did not change things for me.
I touched a wire from the battery to the solenoid input at the starter, and bingo it cranked.
So for me it was not the starter, not the cables, which left the relay box.
But I still have to order the unit.
I ran a separate start button into the cabin and taped it to the harness bar in the man time.
I started the car with a jumped wire to the battery and stop the car after it warmed up.
Wow, the car start with the oem button and wiring now [???]
Is it possible that the ECU was in error and after a start, he relearn how to stat the car?
I just leave the wire spliced from the starter in case of the trouble come back...
1 - 3 of 3 Posts
