1 - 11 of 11 Posts
I'm swapping machined steering arms in for more front camber. Any tips on how to remove the tie rod ends and ball joints without buggering up the rubber seals? I don't want to use the pickle fork. Is there a ball joint press or puller that fits and is readily available. My local O'Reilly's tools don't fit properly.
Hammer method isn't working.
Thanks!
· Banned
There are only 4 bolts holding that whole assembly on...the 2 inner wishbone bolts holding it all to the chassis and the 2 bolts holding the steering arm to the front upright. It all comes out then... much easier to work with then.
Keep track of the caster shims though...
· Tire abuser
Thanks!
3/4" ball joint separator from Harbor Freight (about $20). Slide the split tip in under the rubber boot very carefully. I left the nut on, but very loose so things did not move when that energy is released. I had zero damage on the rubber boots.
Keep the tapered part of the joint very clean. If you get grease on it, they want to spin during re-assembly. I had one that was a little reluctant to get snug so I used a ratchet strap around the a-arm ends. It took just a little pressure to seat enough to get solid.
I replaced these last week and the whole job took less than 2 hours going slowly. Good luck.
· He's on fire!
did what others above did. HF ball joint separator, loosen the nut on the ball joint but leave it on (unless of course you are trying to put a hole through the liner and a ding in the clam). Be mindful of where you place the ball joint separator tool on the threaded end of the ball joint bolt. I managed to mangle a thread on it but fixed it with a couple light touches from the dremel.
· Premium Member
Discussion Starter · #9 ·
I did my control arm bushing upgrade already and it was a bitch ass 12 hr job! I really want to avoid taking those bolts out again...
· Tire abuser
Y'all aren't going to believe this, but the nearest HF is 2500 miles away!!! :facepalm LOL!
Is this the type you used?
Amazon.com is my friend...
Oh, I see your location is a bit...unique. The one you show there might work, but it looks like it would be difficult and might not work.
This is the exact one I used:
3/4" Forged Ball Joint Separator
It worked great.
1 - 11 of 11 Posts
