I am trying to debug an issue with the car and I am looking to see if people have some suggestions.
I recently got the car serviced and replaced my worn out bushings and replaced a failing steering rack with sector's titanrack (2.5 turns instead of 2.75 turns). The shop also did an alignment after replacing the failing parts.
The car goes straight but the wheel is slightly tilted on the left when this happens. Normally I would think this is due to incorrect toe or perhaps a tie rod issue.
However, when I turn the wheel all the way to one or the other side, the wheel stops at different positions. All the way left stops at the 90 degree position, whereas all the way right stops a couple of inches before that. Now I am thinking that this is the mounting of the steering columns in the rack that is off.
Any thoughts about what might be the issue would be appreciated.
I am attaching 3 photos to illustrate this (straight, all right, all left)
