Why is it all twisted?
Remove the zip tie, straighten out the bellows and replace zip tie with a new one :shrug:
But if I were you I would still try to find out why it got all twisted in the first place.
Well I untwisted, put some wd40 under the rubberpart where the zip tie goes over(sector 111 recommended it) since it was really tight and had no play. Thanks for the tip Mr.C.
I had a similar problem when I replaced my rack. The rubber is so tight on the adjustment rod, it twist when the toe is adjusted. I had the noise that Spartacus mentioned. It went away once I got the rubber straightened out.
1 - 4 of 4 Posts
