1 - 11 of 11 Posts
The injectors are not what limits power on the Evora. Much more important are exhaust and intake, where the limit are.
Injectors come last with punched out block. ie 4.0l but not needed before..... unless you can find a way to keep intake temps cool enough to be useful with more power.
Illegal Alien
As brgelise states S injectors are not limits to power with all sane mods; headers and open exhaust, intake, SC pulley and tune which should give power well over 350 at wheels. I say should because I have not changed my pulley. For insane increases intercooler, sleeve out to 4 liter, cams.. will make new injector selection minor, and by then BOE will have full blown tuning capabilities to be able to match them to engine using full parameters and lag times, rather than a fuel scaling fudge factor available under current locked tune selections.
Yea, ehat he said. Thanks Julian as usual.
Discussion Starter · #8 ·
Not sure I would want to go any further than I already have, was just curious.
Thanks for the info.
Illegal Alien
Not sure where you currently are on setup, but most likely we'll inside boundaries first pushed but Ramtin and me, no no worries with stock S model injectors and fuel pump.
Buckwheat -
This is guy down the street from you doing built Evora S engine/ CR Evora gearbox swap into MR2 . The stock units are 550cc. I agree with everyone else for now stock injectors are fine and not needed to be changed .
Once i really get into engine build later in year i will pass on info .
HARROP s/c is out being used in development of new cheaper but better
S/C kit for 2GR
Discussion Starter · #11 ·
Buckwheat -
S/C kit for 2GR
I figured they were 550's. Thanks for the info. Wanted to know for future reference. I look forward to hearing from you.
1 - 11 of 11 Posts
