1 - 14 of 14 Posts
I've had an Elise for 3 years now. Within the last week I noticed that sometimes while downshifting from 3rd to 2nd I feel much less resistance than usual going into 2nd gear. Usually I feel some resistance and notchiness before the gear lever finally goes into gear. When the "problem" happens it I don't much resistance at all, and no notchiness, it feels like I missed the gear, but it is in gear.
Any ideas what is going on?
Chris have you just gotten really good at rev-matching before moving the lever into place? The closer you are to the right rpm, the less work the synchronizers have to do.
It's gotten better and you're complaining?
rotfl
One day at the track last year, I went from the typical knotchiness to a vague feeling, followed by an inability to determine whether the car was in gear or not. Turned out all that driving on a hot track in my turbo car had lead to heat soak and literal melting of the sheath around the transmission cables. Replaced them and placed a lot of heat sheild around them and now it's fine. I don't know if this is your problem or not but it sounds vaguely familiar.
Well I am trying to rev match, but I'm not double clutching so I didn't think the rev matching would make it easier to move the lever, just less slipage/jerking when the clutch engages.
I'd take consistent over occaisionally better any day. Just wondering if it is an early indication of a problem since I only have a few days of warentee left.
Pull your console and check all the fasteners. I had a similar issue when the car was under warranty. Turns out the dealer in California that did the shifter recall did a sloppy job and some of the shifter fasteners were coming loose. Dealer in Atlanta put it back right.
I had a similar problem with the horizontal bolt in the shifter coming loose. Pull the tunnel and check out the torque on the bolts, the cable ends, etc.
Give it to me for a couple of sessions at MSR and I'll get her to grind!
:wave:
Discussion Starter #10
Update: Car is fixed. Overseas had to replace a shift cable under warrantee. Shifting feels better than new now.
Nice.
Show of hands... how many people picked their car up from Overseas today?
:coolnana:
Glad to know I was right, yet again.:cool:
umm. see post #2, you know, three prior to yours...
cables?
try searching some combo of
cable* tran* shift*
-poke-
oh, and this make two expert internet mechanic diagnoses for me today. :clap: (the catastrophic oil leak thread is the other)
:nanner:
too bad i can't fix things in real life.
-poke-
:nanner:
I'm sorry ace, I thought you were probably ignoring me.
No, I'm not sure what that means, really, I just had nothing else brighter to say.:D
1 - 14 of 14 Posts
