1 - 19 of 19 Posts
Driving to work today I noticed a new noise coming from behind me. At around 2K - 3K revs at any gear (well 2 - 6) there is this wet sounding spinning/whistling noise. I'm not much of a gearhead so I don't know much at all about this stuff.
Thoughts? Anyone experience this?
I swear it's the valve in the airbox between opening and closing and it makes a weird winying noise from 3-5k rpm in medium throttle and backing off. What ever, doesn't sound very sexy but it's still running good. :shrug:
I and others I have a sound that starts at about 5000rpm and goes at about 6000rpm and sounds like a weed whacker in the distance.
I have this too, wierd scratchy sound when just kind of slightly letting off 4500-6k rpm maybe?
Have owned 3 Elise's and an Exige and all make this sound.
:tadts:
I said the belt tensioner because I had a noise very similar to what you guys are describing. It had to be replaced. I had ~9500 miles on it. You may want to look into it.
My car has about 23K miles.
No noise when revving the engine at a stand still. No noise when coasting to a stop. Only seems to come out when the car is in gear. But I will have the belt tensioner looked at.
good bet. the toyota belt tensioner on my spyder also required replacement. i hear a similar singing tone on the elise.
I have this sound. Only sounds when I'm at about half-throttle at low speeds, for the most part.
yep, I hear the same thing in my 07 elise. Definitely did not make it when it was bought. Best I can remember it started around 3k miles. Car has about 5k on it now
Yeah mine started around 8700 miles. But what was really strange it was right after picking it up from Criswell after they had it for 3 wks. I felt like they wanted me back in there for more thining wallet service. But after that ordeal I wasn't ever going back to them. :mad:
I have this sound too, its definitely weird. Something with the clutch? Its very similar to the sound my old Evo's 6-puck racing clutch used to make on de-cel.
Just noticed the same thing with my car within the last couple of weeks. I am dropping it off at the local Lotus dealer for other warranty work. I'll specifically ask them to check the belt tensioner out. I'm glad I saw this thread. Thanks Icedog et al.
They ALL have this sound. My Elise AND Exige had it - until I put Stage II exhausts on... Now I can't hear a thing! ;)
shay2nak
LOL it might be bad not to hear the car, you might not hear a rattling noise then have something important fall off.
You could have your entire engine rattling, buzzing, screeching, screaming and grinding and there's no way you'd be able to hear it with that exhaust you have! :bow:
Trust me - I've driven behind you. -poke-
1 - 19 of 19 Posts
