Here's a supercharger setup that I've made, using an air-to-water Laminova intercooler integrated into the intake manifold. I took this approach to minimize the air volume after the supercharger, in order to reduce pressure drop. As you can see, it's a very tight fit. The front and rear engine mount has been filled with polyurethane, so while the IC is close to the firewall, it does not make contact.
The project began as a Tri-Point/Greddy SC kit, which nothing now is being used except for the MP62. The "swan neck" in front comes from the Exige-S supercharger. Everything else is custom fabricated.
The 4 long-core Laminova IC sits on top of the MP62, which blows at an angle to the surge tank and back down again through the short runners. The 6 plugs on top are "access ports", so I can bolt the manifold to the Laminova core. The 4 smaller plugs are for Aquamist water injection - should the need arise.
The oil catch can isn't hooked up yet.
