1 - 10 of 10 Posts
So it is out, and I have a kit, but there are a bunch more bearings in the thing other than the snout.
Is there any reason to think more on that?
Any other things to look at in the MP62 while it is out?
07 Exige S
Yes,
Actually, you should crack the thing open in 3 pieces. Rotors, Case, Snout. Use the red jel like anerobic sealant to re seal it all together again. ( very common and found at all auto stores)
You can check coupler in snout. See if any of the pin openings have rounded out and that it still fits snug. If not replace
In the back of the case are needle bearings. They take a special lube. You can add some, but be warned against too much. I had to take my SC apart again and saw that the blue lube was on the lobes. so I added to much.
I went further... I sanded down all the casting on the intake to be as smooth as the chamber, I also enlarged the outlet a little. If you have any inclination to do this, look through my SC posts years ago and it has links to help explain what is possible with "porting" a MP62.
I also swap out my SC oil every 10k miles. I have a 2.9" pulley and it is def brown color when coming out. There are threads about how much oil to put back in. In essence the bottle has the exact amount. If you have any questions feel free to pm. Peacb
Also since you have it all out, I would put a phenoylic ( spelled wrong) gasket between the intake manifold and head. Just one more barrier for heat to help cool down intake air.
Sold my Exige S
I pulled my supercharger two years ago at 20k miles just for a routine wear inspection. The only problem I encountered was a thin film of oil stuck to the rotors, casing, and inside the swan neck - all of it was blow-by from not using an oil catch can during the car's first few years. I drained around 110mL of oil from the snout and replaced with the exact amount. @exigegus Were your SC issues caused by adding too much oil last time and compromising the seals?
Motard, good points all around, but changing it every 10k miles does sound overkill for street use.
Here are the needle bearings that should be cleaned and lubed.
I was thinking the same thing, but Motard has previously mentioned he has a disease which compells him to do such things.
About how long is it taking you guys to pull, service and replace the supercharger?
San
When I changed the oil last year, there was not enough coming out by about a third. I also have an odd trailing throttle rattle, which made me want to investigate the things I can. The car has 55k miles, and I suspect it was tracked before my ownership.
On opening the snout I find little wrong, I have a kit, so I will rebuild the snout.
Do we know what the grease is that goes on the needles?
Sold my Exige S
I did mine with the rear clam on and the hatch removed. It was still probably a good 3 hours for all the work, servicing the supercharger, and re-installation. The middle nut on the intake manifold was a mean dude.
Well, I am not so quick, but my work was spread out while I did other things
Most of the time is spent finding the correct wrench or socket to fit in a spot.
So, judging by the amount of oil left in, I would not take mine apart again. Since it was at least 30 percent low at 46k miles, I did not know if it lost that amount in 46k miles or the previous 1k miles.
It was 46k miles.
But now I know.
The seal surface is grooved.
It does not look like the shafts are commonly available in a quick search, so I may just clean it up a little and not worry about it.
Has anyone else seen this, addressed it, ignored it?
He's on fire!
I am not so quick either it seems and I don't have an hours estimate for similar reasons. Stuff already mentioned, and stuff I thought would be easy, like the nut on the end of the snout.
If I would have been smart I would have seen if I could get it loose with the belt still on. I had things more apart, so instead I needed a strap wrench... the first one I bought couldn't keep the wheel from slipping, it wasn't until I took a look at some craftsman ones, where the strap was a nice rubber (and therefor grippy) that I found the right tool for the job. I probably spent 2 hours of time just finding a competent strap wrench (when you factor in trying and failing, drive times to more than one hardware store, etc).
Un/Install of the SC was this many times over
1. Looks like I should be able to get at that bolt/nut
2. Access issues make it more difficult than I thought at first
3. Go buy another tool and try it (repeat this step until success)
4. Move on from a task I thought would take a few minutes an hour or two later
I don't have a ton of miles on my car (20k), it is garage kept and well washed... I can't imagine what it would have been like if I'd faced any rust.
Discussion Starter #10
Funny, I actually thought to remove the pulley nut first
AS it turns out, the seal surface is fine, it just had a buildup of goo that made it look like a groove, so a little scotchbrite and off we go.
1 - 10 of 10 Posts
