1 - 16 of 16 Posts
Every morning I get into my Evora and start driving, as it starts to shift from 2nd to 3rd, the RPM's surge up to 5-6k and then drop back down into 3rd. It does this once and that's it. Won't do it again until the next morning. Happens in both normal and sport when in auto.
Does the ECU need to be remapped with updated software??
Thoughts?!
My S IPS did that, Lotus is aware of the problem. The last IPS update solved the problem.
Just got mine back from some warranty work and they said all software was up to date. Aparently Hethel said that those small surges are part of it's transmission, meaning, it won't go away. I have a hard time believing that...
Thoughts?
According to lotus engineers, this is call "flaring"...
had my TCU updated to the latest and it's bad. had flaring on 2-3 or 3-4.
last time i used to have only 3-4. They have updated my TCU 4 times and I felt that the 2nd TCU was the best, no evident of flaring. I have asked lotus to downgrade my TCU firmware to the 2nd.
There is another problem which the TCU upgrade has solved, if you are on sports mode and when you are on metal-to-the-pedal, sometimes the gear gets stuck on 3-4th. It couldn't upshift.
Discussion Starter · #9 ·
Anyone know of a software fix on this yet?!?!
2021 Evora GT
Watching. Do we know the latest software revision date to know if we're current?
I have the latest software update, mine does the same slipping/flaring @ 4k rpm after the update. Also harsh as hell is sport mode when downshifting in auto mode. Its almost more comfortable using the paddles so you dont get the whipping sensation.
2021 Evora GT
For a time stamp.... when did you have the update installed? Any idea of rev #?
I get the same thing. 2013 NA IPS. less than a mile from the house, it over-rev's but then corrects itself and doesn't happen again until after sitting for a very long time (10+ hours). ECU was updated about a month ago but didn't fix it. A lot of people have the problem, it's short lived. Life goes on. Not worth losing sleep over. It's just a cold transmission waking up.
2021 Evora GT
My thought too. Seems to be just a warmup thing. Drive gently for first couple of miles.
it really seems a minor issue - my Cayenne perioidically jostles like this a bit but not so predictable. anywya, i have been able to get around it by just keeping it no higher than 3rd until i get a couple of km's out.
or just crack it a bit harder and the hump is gone for the day.
1 - 16 of 16 Posts
