1 - 13 of 13 Posts
Is there a switched wire in the truck of the Exige (2011 in my case)?
I'm installing a rear camera. I don't want it only connected to work just in reverse - I want it powered on whenever the key is on (or car running).
Before I start hunting around, I thought I'd ask.
Thanks
Scott
They make wireless camera setups
Don't the cameras still need power? I assumed that the "wireless" part meant transmission to the monitor.
Note: I've been wrong before.
Yes. I have the camera. It mounts by the plate and is wired to a wifi transmitter. The camera gets its power from the transmitter. I'm really just looked for advice on where a switched wire would be in the trunk area.
I think wireless is from the transmitter to the monitor... I don't think power has gone wireless yet. Most wireless cameras get their power from a tap to the reverse light which powers the camera and transmitter.
Turning on the parking lights/headlights will lite the rear tail lights... so tapping that bulb may give you rear camera as long as the parking/headings were on. I assume the voltage to the reverse lights and the parking lights are the same... but I'm not sure.
sorry to necro this thread, but was there an identified wire to tap into to power the rear camera? I just got the Garmin BC30 rear camera and I'm looking to connect it to a similar switched power location in the trunk of my Exige.
I think some cars had a wire there for European rear fog lights, but it's been a long time.
Do you want your camera to be one all the time or only when in reverse?
In latter case, your b/u lights are powered then.
I was looking to have the camera always on. I've been looking through the electrical diagram from the repair manual but it looks like I may have to try and wire it to the fuse box.
The license plate light has a nice slot already cut out next to where the light is bolted on and I used that to feed the camera line through into the trunk.
I think you're right.
1 - 13 of 13 Posts
