1 - 7 of 7 Posts
Syvecs PnP for Lotus Elise 2006 + ( including sensors )
I had this on my turbocharged Elise and we were just going through initial tuning whilst communicating with Gareth at Eliseracing in UK. Unfortunately, I had to delay and then abandon this project. It's been used for maybe 6 hours with the sensors.
Its near mint.
In Gareth's own words "the ecu offers unrivalled engine protection with adaptive individual cylinder knock analysis and trip to protect the engine in relation to engine coolant temp, oil pressure, oil temp, air temp, VVT fail, lambda lean triop, the list goes on."
Its retails for $3000 plus sensors. This has the wideband O2 sensor, MAF sensor, 4bar boost, manifold temp.
"The S6GP ECU offers an extremely high level of precise engine management control. The twin processor unit uses a high speed RISC processor for code execution and an additional large FPGA for high speed engine position tracking, allowing the scheduling of code to be independent of signal patterns, increasing flexibility, efficiency and accuracy under transient conditions. This powerful combination also allows advanced control algorithms but yet easy to map for the end user.
The S6Plus ECU offers an extremely high level of precise engine management control. The triple processor unit uses a high speed RISC processor for code execution and an additional large FPGA for high speed engine position tracking, allowing the scheduling of code to be independent of signal patterns, increasing flexibility, efficiency and accuracy under transient conditions. This powerful combination also allows advanced control algorithms but yet easy to map for the end user still using our SCal software and S6 Firmware.
The Third Processor present is available for in the future users to write their own code in C for Full Vehicle Integration via Canbus and Build some custom strategies to handle some of the unique requirements which are now found in OEM Applications. Currently only Syvecs staff can do this but we are working on offering this out to all our dealers very soon!
Cased In A Sealed Aluminium Billet Unit With 3 x Waterproof Connectors Offering 94pins
Inputs
22 x General Purpose Analogue Inputs:
4 x 5V/Bipolar, Sensor/Sync/Speed, Programmable Trigger Voltages
10 x 5V/Thermistor, Sensor/Sync/Speed, Fixed Trigger Voltages
4 x 5V Sensor Input
4 x Thermistor Sensor Input
2 x Lambda Inputs Including:
- 1 x NTK, Bosch LSU4.2/4.9 or Denso AF Lambda Circuit
- 1 x Bosch LSU4.2/4.9 or Denso AF Lambda Circuit
2 x K-Type Thermocouple Circuits
2 x Knock Inputs
Outputs
24 x High/Low Side Driver Outputs:
8x Half Bridge Outputs (Max 10 Amps)
16 x Low Side Injection/PWM Outputs (Max 10 Amps)
6 x TTL Ignition Driver Or Direct Coil Drive IGBT (Solder Bridge Settings on Board)
Comms
1 x Can 2.0B
1 x Rs232 Output
1 x Kline Output
100 Mhz Full Duplex Ethernet For Connection To PC For Programming And Data Download
1MB Battery Backed Internal Logging Memory, Onboard Laptop Logging and USB Logging to be supported in the near Future for near unlimited logging of certain parameters"
$2750. + Shipping
1 - 7 of 7 Posts
